Announcements
Error has occurred while loading color management policy file
jiajun.coding
jiajun.coding
Hi all,
My Maya needs to use another .ocio config file from another application to make them use same color space. But when I open the maya file, I got an error saying "Error has occurred while loading color management policy file". The target file path is correct because I used the environment path to point to it directly.
That is, "set MAYA_COLOR_MANAGEMENT_POLICY_FILE=X:\MyFolder\config.ocio" in my batch file which uses to open maya.
jiajun.coding
OK. I solved it by searching my .ma file. And I can know which .ocio file it wants to use in my computer~
Then I just make the missed .ocio file back. Everything goes right.
