Announcements
Drop-down box Menu Items Command
Admiral.Pixel
Admiral.Pixel
Hi all! How can I run commands on menuItems when selected? I was trying to make a def function but don't know how to properly execute it
cmds.optionMenu(label='Pivot', changeCommand=pivotOrient)
cmds.menuItem( label='Object', )
cmds.menuItem( label='World')
cmds.menuItem( label='Component' )
cmds.menuItem( label='Normal' )
When I select "Object" the pivot orientation changes to "object", when I select "World," the pivot orientation changes to "world" and so on. I know that the feature is already in the Modeling Toolkit but I'm trying to make a custom-built and a simplified version of it. Thanks in advance.    Untitled.png
Roland.Reyer
The function that you provide in the "changeCommand" option gets called when the user chooses another option in the dropdown.
The function has to find out what the new value is. For that it is a good idea to pass the name of the UI element so that the function can query the new value:
pivotMenu = optionMenu( label='Pivot')
optionMenu( pivotMenu, edit=1, changeCommand='pivotOrient( pivotMenu)')
Your function pivotOrient can now query the state of the menu pivotMenu and set the pivot accordingly.
