DrawStyle
DrawStyle
DrawStyle
Hi all, how're you?.
I'm doing a script, but i'm really beginner in that, so i searching help...i holpe that anyone can help me.
Well, i did some lines of code that the funtion of that it's turn on the drawstyle(none). It's my first line
My second code its to put my drowStyle in bone.
But my question i'ts, how can i turn off and turn on my draw style with only a few clicks?
I resolved that with two bottoms but i just want one bottom.
1 click = drawStyle in none
2 click = drawStyle in Bone
and vicebersa.
thx!
jmreinhart
The easiest way to set up a button is to create one of the shelf. In case you don't know how do that here is a video:
https://www.youtube.com/watch?v=yraBRus3Q7w
Once you have a button you can set up a different script for single and double click by right clicking on the button and choosing edit
Single click (to set the drawStyle on the selected joints to none)
import maya.cmds as cmds
sel = cmds.ls(sl = True)
for each_joint in sel:
    if cmds.nodeType(each_joint) == 'joint':
        cmds.setAttr(each_joint + '.drawStyle', 2)
Double click   (to set the drawStyle on the selected joints to bone)
        cmds.setAttr(each_joint + '.drawStyle', 0)
Thanks!!
arshkumarmishra
thanks a lot
