Disable double click time slider select all. (Python/2017)
I have been trying to disable the double click select all function of the Time Slider, because it is more irritating than useful.
I have gone down two paths with this and come up blank each time.
I have tried using timeControl:
import maya.mel as mel
time_control = mel.eval('$tempMelVar = $gPlayBackSlider')
cmds.timeControl(time_control, q=1, var)
But there are not functions, or callbacks to help with the double click functionality here.
And I have tried the more obscure Qt route:
from PySide2 import QtWidgets, QtCore, QtGui
import maya.OpenMayaUI as omui
import shiboken2 as shiboken
MAYAWINDOW = shiboken.wrapInstance(long(omui.MQtUtil.mainWindow()), QtWidgets.QWidget)
time_control_path = cmds.timeControl(time_control, q=1, fullPathName=True) qt_frame = MAYAWINDOW.findChildren(QtWidgets.QWidget) for i in qt_frame: if i.objectName() == time_control_path.split("|")[-2]: qt_widget = i
I am using Maya 2017.
Any ideas on this would be appreciated.
lee.dunham
Haven't tried, but I would probably look at installing an eventFilter for the time slider QObject.
Bear in mind that you'll probably need to deduce a double click event by capturing the time between clicks.
Interesting, I'll check it out when I have some more time.
Thank you for your response!
