dirtyPlugExists always true?
I'm writing some custom nodes using the API and I can't figure out how to detect if an attribute has actually changed:
my node have input (integer) attributes in_a, in_b and outputs out_c.
both inputs are needed for calculation of c, but I want to perform additional calculation when b changed.
basically I have this
MStatus mynode::preEvaluation(const MDGContext& context, const MEvaluationNode& evaluationNode) { ... if( (evaluationNode.dirtyPlugExists(in_a, &status) && status) || (evaluationNode.dirtyPlugExists(in_b, &status) && status)) { needRefresh = true; } if(evaluationNode.dirtyPlugExists(in_b, &status) && status) { mustperformadditionalstuff = true; } return MStatus::kSuccess; }
basically it works fine, except that when I have some keyframes on b, this function
always returns true, on every single frame.
It's not expected since on most frames the value doesn't change. but now my boolean is always set to true;
Am I missing something about the way we can track if an input plug is dirty?
thanks
