Detecting overlapping Uvs on a certain uvset
Craig_Lamorte
Message 1 of 9
Craig_Lamorte
I am trying to write some code that will detect if there are overlapping Uvs only on the 2nd uvset (not map1).  I did find this command polyUVOverlap(selected_uvs, oc=True), and it appears to work if there is only one uvset, and will properly return any uvs that are overlapping.  However when I am working with 2 uv_sets on a mesh, and i select that second uv set and it's uvs, no matter what it will return nothing.  But it will return something if its selected on map1.  Anyone have any ideas?
Replies (8)
Message 2 of 9
mspeer
Hi!
You need first to define the "current" UV Set.
MEL example:
polyUVSet -cuv -uvSet "uvSet";
Message 3 of 9
Craig_Lamorte
oh yes, I do define which uv set before i select the Uvs and run the polyoverlap command.
polyUVSet(uvSet='uvSet', currentUVSet=True)
If i define the uvSet as 'map1' it will detect overlapping uvs, but not when i make it select the 2nd uv set
Message 4 of 9
mcw0
First thought would be to duplicate your mesh.  Copy the second uvSet to map1.  Do your detection and transfer the results back to your original mesh.
Message 5 of 9
mspeer
Hi!
What Maya version are you using?
(Here it works fine with Maya 2020.3)
Please provide an example scene and the complete script for the second UV Set, which does not work.
Message 6 of 9
Craig_Lamorte
hmm Im having troubles now getting the pm.polyUVOverlap command even working on a more complicated mesh with just 1 uvset.  I messed up the uvs so they are definitely overlapping each other and run this
mesh = pm.ls(sl=True)
uvs = pm.polyListComponentConversion(mesh, toUV=True)
pm.select(uvs)
print pm.polyUVOverlap(uvs, oc=True)
with the mesh selected it returns None everytime.
Message 7 of 9
mcw0
polyUVOverlap takes faces.  Your polyListComponentConversion is returning uvs.
Message 8 of 9
Craig_Lamorte
ohhhh, oops.  Thats where it was messing up, thanks.  I guess I assumed it would be fed UVS, not faces. Thanks
Message 9 of 9
mspeer
Hi!
@Craig_Lamorte  and @mcw0
Edges would also work. Overlapping is really checking for individual overlapping areas (faces) or lines (edges).
This does not work with points.
