Deselect transform tools (before calling function)
coeuscreative
coeuscreative
I have a python script that's processing all the vertices in a mesh.
I've noticed that if I run it with any of the transform tools active it runs much slower than if I have the select tool active. This isn't a big deal, but I was wondering two things...
Is there anything in my script that might be causing this?
And/or, is there any command I can insert at the beginning of the function to ensure that the select tool is active rather than any other tool, something like...
def processVerts():
    cmds.actvateSelectTool
    doVertStuff
jmreinhart
I assume that you are selecting the verts during the script?
Maya manipulators are special DAG nodes (strange I know), but that means that when the selection changes they have to run calculations for the new selection. I wouldn't expect it to be a major slowdown but I suppose it's possible depending on your selection settings.
This should work:
cmds.setToolTo('selectSuperContext');
coeuscreative
Perfect thanks
