Announcements
Custom Script works only once - Obj is not callable
The-Digital-Shaman
The-Digital-Shaman
Hi there,
I am learning to source code from external files.
That's a default path for custom scripts:
...\Documents\maya\2022\Scripts\
However, I am grouping some of them in here:
...\Documents\maya\2022\Scripts\Sourced\
Having to navigate to another folder causes some challenges I try to understand.
I.e. Joe's script is run by calling a function named rapidPlace() inside the code.
I renamed *.py file to "JoeWu_RapidPlace_266", placed in the "Sourced" directory now I'm trying to run it using this script:
from Sourced import JoeWu_RapidPlace_266
rapidPlace()
Result:
# Error: NameError: file <maya console> line 10: name 'rapidPlace' is not defined #
Even without renaming python files, I still can't make them work from the "Sourced" folder.
Some similar scripts do work, but only once and then;
# Error: TypeError: file <maya console> line 12: 'module' object is not callable #
This is the case with SpeedCut, which I call using this script;
from Sourced import JoeWu_SpeedCut
JoeWu_SpeedCut()
Is it apparent what mistake am I making?
Cheers,
DS
Kahylan
Hi!
You are importing your module correctly, but you aren't telling maya what module you want to run your function from.
Correct Synthax would be this:
JoeWu_RapidPlace_266.rapidPlace()
The second error stems from the fact that you are trying to call your script like a function. Your Module is called "JoeWu_SpeedCut" but you can't call the module directly. You need to call a function or class inside it. If there isn't a function in the script, open the script file and place the entire script inside a function called "execute" and call it as follows:
JoeWu_SpeedCut.exectue()
I hope it helps!
The-Digital-Shaman
I see...makes sense.
It works now.
Much appreciated!
