custom file node with animation on the attributes not running compute method
I have a custom file node with an index to animate textures.
If I put values manually works.
But when the attribute has animation doesn't execute the compute method.
How can I trigger compute or set the attribute dirty when I hit play on the viewport.
thanks,
-Alex
cheng_xi_li
Autodesk Support
Autodesk Support
Hi Alex,
How should I use your sample code in Maya? Do you have a scene or steps so I could set it up like you did?
Yours,
Li
