Custom File Menu Refresh Crash
Hey.
So I'm creating a custom file menu inside maya and have successfully done this reading a yaml file to loop through and create all the menus/submenus/menuItems. A python file/function is called within the userSetup.py file just fine and the menu shows up and is working when launching maya. However, I have one menuItem button I want to use to refresh this custom menu if I update the yaml file with Maya already open.
I created a python function to do just this that essentially will delete the custom menu and all items underneath it and then run the original createMenu function to re-create the menu with the updated yaml file. To my surprise, when I launch the refresh menu button, it runs through the full code (all lines are executed without error) and then Maya crashes. No idea what is going on. If my code is executing all the way through with zero error, why would Maya crash afterwards?
I went and found Maya's crash log and here's the most recent crash log I got:
//===================================================== Maya Crash Report //===================================================== Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000028 Fault address: 59D5A46D in C:\Program Files\Autodesk\Maya2019\bin\Qt5Widgets.dll 0001:0006946D Logical offset (see .map file for location) Call stack: Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Widgets.dll (-exported-) Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 112 bytes Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64 Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Widgets.dll (-exported-) Location: Qt5Widgets.dllQApplication::notify + 1B27 bytes Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64 Module: C:\Program Files\Autodesk\Maya2019\bin\ExtensionLayer.dll (-exported-) Location: ExtensionLayer.dllTwindowManager::windowPreferencesAreEnabled + 3CD bytes Decl: public: bool __cdecl TwindowManager::windowPreferencesAreEnabled(void)const __ptr64 Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-) Location: Qt5Core.dllQCoreApplication::notifyInternal2 + B9 bytes Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64) Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Gui.dll (-exported-) Location: Qt5Gui.dllQGuiApplicationPrivate::processMouseEvent + 7F3 bytes Decl: public: static void __cdecl QGuiApplicationPrivate::processMouseEvent(class QWindowSystemInterfacePrivate::MouseEvent * __ptr64) Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Gui.dll (-exported-) Location: Qt5Gui.dllQWindowSystemInterface::sendWindowSystemEvents + 9B bytes Decl: public: static bool __cdecl QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-) Location: Qt5Core.dllQEventDispatcherWin32::processEvents + DA8 bytes Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64 Module: C:\Windows\System32\USER32.dll (-exported-) Location: USER32.dllCallWindowProcW + 3BD bytes Module: C:\Windows\System32\USER32.dll (-exported-) Location: USER32.dllDispatchMessageW + 1F2 bytes Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-) Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 4D6 bytes Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64 Module: C:\Program Files\Autodesk\Maya2019\plugins\platforms\qwindows.dll (-exported-) Location: qwindows.dllqt_plugin_query_metadata + 24B9 bytes Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-) Location: Qt5Core.dllQEventLoop::exec + 1B3 bytes Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64 Module: C:\Program Files\Autodesk\Maya2019\bin\Qt5Core.dll (-exported-) Location: Qt5Core.dllQCoreApplication::exec + 147 bytes Decl: public: static int __cdecl QCoreApplication::exec(void) Module: C:\Program Files\Autodesk\Maya2019\bin\ExtensionLayer.dll (-exported-) Location: ExtensionLayer.dllTapplication::start + CE bytes Decl: public: void __cdecl Tapplication::start(void) __ptr64 Module: C:\Program Files\Autodesk\Maya2019\bin\maya.exe (-exported-) Location: maya.exe<7FF7C7F277A8> Decl: ?? Module: C:\Program Files\Autodesk\Maya2019\bin\maya.exe (-exported-) Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + F504 bytes Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++ Module: C:\Program Files\Autodesk\Maya2019\bin\maya.exe (-exported-) Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + E47F bytes Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++ Module: C:\Windows\System32\KERNEL32.DLL (-exported-) Location: KERNEL32.DLLBaseThreadInitThunk + 14 bytes Module: C:\Windows\SYSTEM32\ntdll.dll (-exported-) Location: ntdll.dllRtlUserThreadStart + 21 bytes End of stack //crash log file name = C:\Users\rwie\AppData\Local\Temp\MayaCrashLog200221.1645.log //version = 19.2.0.8774 //cut = Tue 07/02/2019, 201907021628 //current scene = unDisclosed //command history (most recent last): //==================================================== //last tool: renderWindowSelectContextItem //==================================================== //panel with focus: graphEditor1 //visible panels: // modelPanel4 graphEditor1 scriptEditorPanel1 //==================================================== //Memory usage: // 45642.410 Mb Free Memory // 46479.031 Mb Free Swap // 1481.117 Mb Current //====================================================
If anybody has a specific way to refresh a custom maya file menu, I would much appreciate seeing how that's done without crashing maya.
Thanks for the help!
