Creating virtual polygons?
I would like to create in cpp multiple polygons, that are not referrenced in the outliner but that I can select in the interface and then move using cpp code (not interactively).
What cpp command should I use or is there a simple code sample out there I could reuse ?
Thanks !
RFlannery1
I'm not sure that is possible.  Why do you want the polygons to not show up in the outliner?
I would like to create hundreds of virtual duplicates of an existing object, without the need to having all of them in the outliner and want to display proxies (like cubes) to take less memory, and then having the real object at render time.
If I take an example provided by Autodesk, LineManipulator, a line + text are drawn in the UI. I would like to know if the same can be done with a mesh or if I have to draw for example 12 lines for a cube.
RFlannery1
Ah, I see now.  Unfortunately, I am not really familiar with rendering things in the viewport, so I can't offer any advice.
