Create mesh from list
Is it possible to create a mesh in Python from a list? For example, I have a list of vertices in a list that I know will make up a cube. How do I loop over the list and creat each vertex in turn?
import maya.cmds as cmds
myCube = [
-0.5,   -0.5, 0.5,
0.5,   -0.5, 0.5,
0.5,   0.5, 0.5,
0.5,   0.5, 0.5,
-0.5,   0.5, -0.5,
0.5,   0.5, -0.5,
-0.5,   -0.5, -0.5,
0.5,   -0.5, -0.5
for x, y, x in myCube: # I have no idea
  create vertex (x,y,z) # This is just a guess
At the emoment I'm just interested in creating each vertex. I'll fill in the faces later by hand.
Hi
AFAIK, maya does not provide a specific class to create just a bunch of vertices.
All vertices are instances of the Maya.MPoint() or Maya.MFloatPoint() classes in the Maya API.
So you cannot say something like SomeVertexClass.createVertex() and expect to see a vertex in the viewport.
However, if you know the location of you vertices, you can use other APIs to create your mesh.
For example, you could use MFnMesh class from the Maya API to create a mesh as follows.
(The Maya documentation is very detailed so please refer to the link to know details of the API)
# using Python API 2.0 for Maya
import maya.api.OpenMaya as om
meshFn = om.MFnMesh() # list of vertex points vertices = [om.MPoint(-0.5, -0.5, 0.5), om.MPoint(0.5, -0.5, 0.5), om.MPoint(0.5, 0.5, 0.5), om.MPoint(-0.5, 0.5, 0.5), om.MPoint(-0.5, 0.5, -0.5), om.MPoint(0.5, 0.5, -0.5), om.MPoint(0.5, -0.5, -0.5), om.MPoint(-0.5, -0.5, -0.5)] # list of number of vertices per polygon # A cube has 6 faces of 4 vertices each polygonFaces = [4] * 6 # list of vertex indices that make the # the polygons in our mesh polygonConnects = [0,1,2,3,1,6,5,2,7,6,5,4,3,2,5,4,3,0,7,4,0,1,6,7] # create the mesh meshFn.create(vertices, polygonFaces, polygonConnects )
For a simple cube like the one you provided in your question though, I wouldn't bother with the API and just use the polyCube() command to draw the cube.
import maya.cmds
cmds.polyCube()
