Create key
Create key
dg3duy
Create key
dg3duy
Let's suppose I have 2 animation keys...
they are separated by X amount of frames, which we do not know.
How is it possible to create keys in percentage between those 2 keys?.....
for example, to create a key in 25%
another at 50%
another at 75%
Any idea where to investigate this?
Kahylan
Hi!
The "findKeyframe" command can help you find out the time value of the keys and from there on out it's just a little bit of math and using the "setKeyframe" command to acctually key what you want.
So as a simple example, if you have the first key selected in the timeline and you want to insert a keyframe at 50% of time to the next keyframe on the selected object:
import maya.cmds as mc
def insertKeyPercentage(percentage = 50):
    key1 = mc.currentTime(q = True)
    key2 = mc.findKeyframe(t = (key1,key1), w = "next")
    p = ((key2-key1)/100)*percentage
    newKey = mc.setKeyframe(i = True, t = (key1 +p))
I hope it helps!
dg3duy
it's great, thank you very much...
dg3duy
What if you want to automatically select the new key created in the curve editor?
Kahylan
Since you already have the timerange defined, you can just use the select key command on that timerange with a buffer off 0.0001 on each side to select all the keyframes created by the command:
    mc.selectKey(clear = True)
    mc.selectKey(time = (key1+0.0001, key2-0.0001), k = True)
Now this will cause problems if the timespan between key1 and key2 is less than 0.0002 frames, but if that is the case, your scene has bigger problems anyways.
But I should also mention, that I added in a clearing of the key selection, since otherwise the program could not be run twice in a row without manually deselecting the keys
dg3duy
fantastic! very useful, thank you very much.
