crash when I create nCloth in FX mode
443005358
Message 1 of 1
443005358
Community Visitor
Community Visitor
When I use FX mode and try to create ncloth or create a passive collider, Maya stops working and shows an error.
The logs:
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x47B65FF8
Fault address:  5D961D42 in C:\Maya2024\bin\awnSolver.dll
0001:00030D42 Logical offset (see .map file for location)
Call stack:
Module:  C:\Maya2024\bin\awnSolver.dll (-exported-)
Location: awnSolver.dllaw_api_nSolver::api_nDynamicalComplex::allocate + 41 bytes
Decl: protected: void __cdecl aw_api_nSolver::api_nDynamicalComplex::allocate(int,int * __ptr64,int * __ptr64,int,int * __ptr64) __ptr64
Location: awnSolver.dllaw_api_nSolver::api_nCloth::set_topology + 58 bytes
Decl: public: void __cdecl aw_api_nSolver::api_nCloth::set_topology(int,int * __ptr64,int * __ptr64,int,int * __ptr64) __ptr64
Module:  C:\Maya2024\bin\DynSlice.dll (-exported-)
Location: DynSlice.dllTnClothShape::setupInputMesh + 79 bytes
Decl: protected: virtual int __cdecl TnClothShape::setupInputMesh(class TncMesh & __ptr64,class TdataBlock & __ptr64) __ptr64
Location: DynSlice.dllTnBaseShape::initializeNObject + 1C7 bytes
Decl: public: virtual void __cdecl TnBaseShape::initializeNObject(class TdataBlock & __ptr64) __ptr64
Location: DynSlice.dllTnClothShape::computePlug + 54 bytes
Decl: public: virtual void __cdecl TnClothShape::computePlug(class Tplug const & __ptr64,class TdataBlock & __ptr64) __ptr64
Module:  C:\Maya2024\bin\DependEngine.dll (-exported-)
Location: DependEngine.dllTdependNode::dbEvaluate + 4BF bytes
Decl: protected: virtual bool __cdecl TdependNode::dbEvaluate(class TmsgEval & __ptr64) __ptr64
Module:  C:\Maya2024\bin\DataModel.dll (-exported-)
Location: DataModel.dllTdagObject::dbEvaluate + 1B bytes
Decl: public: virtual bool __cdecl TdagObject::dbEvaluate(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::stackSafeDbEvaluate + 98 bytes
Decl: protected: bool __cdecl TdependNode::stackSafeDbEvaluate(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::mpSafeDbEvaluate + 2A bytes
Decl: protected: bool __cdecl TdependNode::mpSafeDbEvaluate(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::processEval + 1CF bytes
Decl: protected: virtual bool __cdecl TdependNode::processEval(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTevaluationDebug::operator= + CE8 bytes
Decl: public: class TevaluationDebug & __ptr64 __cdecl TevaluationDebug::operator=(class TevaluationDebug const & __ptr64) __ptr64
Location: DependEngine.dllTplug::evalConnectionValue + D5 bytes
Decl: public: bool __cdecl Tplug::evalConnectionValue(bool,class TdgContext const & __ptr64,class TdataHandle & __ptr64)const __ptr64
Location: DependEngine.dllTplug::evaluateValue + E3 bytes
Decl: public: bool __cdecl Tplug::evaluateValue(class TdataHandle & __ptr64,class TdataBlock const & __ptr64,bool)const __ptr64
Location: DependEngine.dllTdataBlockDG::evaluateValue + 38 bytes
Decl: private: void __cdecl TdataBlockDG::evaluateValue(class Tplug const & __ptr64,class TdataHandle & __ptr64) __ptr64
Location: DependEngine.dllTdataBlockDG::value + 158 bytes
Decl: public: virtual class TdataHandle __cdecl TdataBlockDG::value(class Tattribute const & __ptr64) __ptr64
Module:  C:\Maya2024\bin\Poly.dll (-exported-)
Location: Poly.dllTmeshShape::computeObject + 222 bytes
Decl: protected: void __cdecl TmeshShape::computeObject(class Tplug const & __ptr64,class TdataBlock & __ptr64) __ptr64
Location: DependEngine.dllTdependNode::mpSafeDbEvaluateWithSet + 80 bytes
Decl: protected: bool __cdecl TdependNode::mpSafeDbEvaluateWithSet(class TmsgEval & __ptr64) __ptr64
Location: DependEngine.dllTplug::processEval + 69 bytes
Decl: private: bool __cdecl Tplug::processEval(class TdgContext const & __ptr64,class TdataHandle * __ptr64)const __ptr64
Location: DependEngine.dllTplug::evaluateValue + 537 bytes
Decl: public: class TmidBody * __ptr64 __cdecl TmeshShape::midBody(void)const __ptr64
Location: Poly.dllTmeshShape::getPolyGeomFromMeshShape + E bytes
Decl: public: static class TpolyGeom * __ptr64 __cdecl TmeshShape::getPolyGeomFromMeshShape(class TmeshShape const * __ptr64)
Module:  C:\Maya2024\bin\OGSMayaBridge.dll (-exported-)
Location: OGSMayaBridge.dllOGSMayaFileTexturePacker::pack + 2D2F bytes
Decl: public: virtual bool __cdecl OGSMayaFileTexturePacker::pack(class TfileTexturePackerInput & __ptr64,class TfileTexturePackerData & __ptr64,bool) __ptr64
Location: OGSMayaBridge.dllOGSMayaFileTexturePacker::pack + 3D16 bytes
Location: OGSMayaBridge.dllTtask::syncExecuteChildren + 24A bytes
Decl: private: void __cdecl Ttask::syncExecuteChildren(void) __ptr64
Location: OGSMayaBridge.dllOGSApplicationBridge::UpdateScene + 10D bytes
Decl: public: bool __cdecl OGSApplicationBridge::UpdateScene(class OGSApplicationUpdateCallback & __ptr64) __ptr64
Location: OGSMayaBridge.dllOGSMayaRenderer::updateScene + 203 bytes
Decl: public: bool __cdecl OGSMayaRenderer::updateScene(class OGSApplicationUpdateCallback & __ptr64,bool * __ptr64) __ptr64
Location: OGSMayaBridge.dllOGSMayaBaseRenderer::performSceneRender + 153 bytes
Decl: public: virtual bool __cdecl OGSMayaBaseRenderer::performSceneRender(class OGSMayaSceneOperation * __ptr64,unsigned __int64,bool * __ptr64) __ptr64
Location: OGSMayaBridge.dllOGSMayaStrokePainter::isViewInfoLegal + 6BE bytes
Decl: public: virtual bool __cdecl OGSMayaStrokePainter::isViewInfoLegal(void)const __ptr64
Location: OGSMayaBridge.dllOGSMayaStrokePainter::isViewInfoLegal + 104E bytes
Location: DataModel.dllTidleRefreshCmd::refreshOGSRender + 3BA bytes
Decl: private: static bool __cdecl TidleRefreshCmd::refreshOGSRender(class T3dView * __ptr64,bool,bool,enum TdisplayAppearance,bool,bool,bool)
Location: DataModel.dllTidleRefreshCmd::refresh + 2A4 bytes
Decl: public: static void __cdecl TidleRefreshCmd::refresh(class T3dView * __ptr64,enum TdisplayAppearance,bool,bool,bool,bool,bool,bool)
Location: DataModel.dllTidleRefreshCmd::doIt + 218 bytes
Decl: public: virtual bool __cdecl TidleRefreshCmd::doIt(class Tevent const & __ptr64) __ptr64
Module:  C:\Maya2024\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTeventHandler::doIdles + 122 bytes
Decl: public: static bool __cdecl TeventHandler::doIdles(void)
Location: ExtensionLayer.dllTeventHandler::suspendIdleEvents + 311 bytes
Decl: public: static void __cdecl TeventHandler::suspendIdleEvents(void)
Module:  C:\Maya2024\bin\Qt5Core.dll (-exported-)
Decl: public: virtual bool __cdecl QObject::event(class QEvent * __ptr64) __ptr64
Module:  C:\Maya2024\bin\Qt5Widgets.dll (-exported-)
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 110 bytes
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplication::notify + 18B3 bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: ExtensionLayer.dllQmayaApplication::currentSystemMouseButtons + 62C bytes
Decl: public: static class QFlags<enum Qt::MouseButton> __cdecl QmayaApplication::currentSystemMouseButtons(void)
Location: Qt5Core.dllQCoreApplication::notifyInternal2 + BA bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Core.dllQEventDispatcherWin32::event + D0 bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::event(class QEvent * __ptr64) __ptr64
Location: Qt5Core.dllQCoreApplicationPrivate::sendPostedEvents + 215 bytes
Decl: public: static void __cdecl QCoreApplicationPrivate::sendPostedEvents(class QObject * __ptr64,int,class QThreadData * __ptr64)
Module:  C:\Maya2024\plugins\platforms\qwindows.dll (-exported-)
Location: qwindows.dllqt_plugin_query_metadata + 1FBF bytes
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 6A bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: qwindows.dllqt_plugin_query_metadata + 1F99 bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: Qt5Core.dllQCoreApplication::exec + 154 bytes
Decl: public: static int __cdecl QCoreApplication::exec(void)
Location: ExtensionLayer.dllTapplication::start + E5 bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module:  C:\Maya2024\bin\maya.exe (-exported-)
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 1460 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 17E97 bytes
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 16E16 bytes
Module:  C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
Module:  C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\banan\AppData\Local\Temp\MayaCrashLog240304.2251.log
//version     = 24.2.0.1186
//cut            =  10/18/2023, 202310181224
//current scene = unDisclosed
//command history (most recent last):
//last tool: nurbsSelect
//panel with focus: modelPanel4
//visible panels:
// modelPanel4 outlinerPanel1
//Memory usage:
// 3805.547 Mb Free Memory
// 8631.867 Mb Free Swap
// 2315.871 Mb Current
Replies (0)
