Check if attribute value changes over time.
wynand.lens
wynand.lens
I know you can see if there is a value change if the attribute is keyed using:
keyed_values = cmds.keyframe('obj.attr', q=1, valueChange=1)
But, if it is driven by a connection, I can't see if there is a value change, unless I check every attribute across every frame on my timeline. And that is obviously incredibly inefficient.
Is there a way to Check if an attribute's value changes over time if its connected to something other than an animCurve?
I need a command to detect that these attributes are actually changing over time!
brent8S64J
Do you need to check it once, or check it all the time?  If you need to check it once - you can use a number of methods, a frameCache node, or a loop of getAttrs at different times.  If you need to check it all the time, you may need a scriptJob or a script that evaluates on every frame change.  Give me a bit more description of what you want your user experience to be like, and I'll write you the code that does it.
