Announcements
-cc & -ec wont write the variable?
Here's what I have (within my window )
textField -w 200 -tx $gVar_ccAttr_specFootAttr -ec wv_ccAttr_heelUpDown ccAttr_heelUpDown_txField;
the proc being called is in a .mel file with all the other wv_ procs (around 21 of them, all the same layout as this one;other ones wont work properly either)
global proc wv_ccAttr_heelUpDown()
global string $gVar_ccAttr_heelUpDown_txField;
global string $gVar_ccAttr_specFootAttr[];
print ("Variable updated; New value applied to $gVar_ccAttr_specFootAttr .");
$gVar_ccAttr_specFootAttr = `textField -query -tx $gVar_ccAttr_heelUpDown_txField`;
print "Update procedure Complete.";
The odd thing is: when I do change the textfield, the print commands are executed just fine. sourcing the scripts isnt a problem either.
But the variable simply isn't being updated. -.-*
It works just fine when I run the
when the window is open. But somehow MEL wont do that if its triggered by the -ec nor the -cc flags of the textfield.
I dont want to break up my pretty UI with a bunch of ugly buttons again to execute the procs. :<
Any help's appreciated! 🙂
lee.dunham
hmm sounds like Maya doesnt know what textField to query, so the steps between calling the proc and the proc sourcing the global var
Where are you telling maya the name of the textField?
Personally, unless I absolutely had to, I wouldnt bother using global vars to store the name of entryFields I want to query or edit, and I cant think of a reason you'd need to.
Instead i'd pass their name as through an argument.
textField -w 200 -tx $gVar_ccAttr_specFootAttr -ec "wv_ccAttr_heelUpDown "\ccAttr_heelUpDown_txField"\" ccAttr_heelUpDown_txField;
global proc wv_ccAttr_heelUpDown(string $tField)
$gVar_ccAttr_specFootAttr = `textField -query -tx $tField`;
print “Update procedure Complete.”;
I store them in gVars cuz I know how I tend to rename stuff every other release, so this way I only have to change it in the init script, where I tell maya the name of the fields. 😛
But I'll give it a shot if it works like that. Thx lee 🙂
