Catching maya's error message
viru.gupta8
viru.gupta8
hello,
i have a code where i am using try and except
ex:
try:
    do_something()
except:
    cmds.warning("some error")
this function may give some error ex: "pCube03 not found", "can't constraint pCube02"
how can we catch that error message and use that in except as warning.
RFlannery1
Try this:
try:
    do_something()
except Exception as e:
    cmds.warning(str(e))
If that doesn't give the message you want, you can also try replacing the last line with:
cmds.warning(e.message)
You may not get it directly, but you can get it indirectly
# Begin recording the Script Editor history to a file called
# tempHistoryLog.txt in your maya directory.
cmds.scriptEditorInfo( historyFilename='D:/tempHistoryLog.txt', writeHistory=True )
When it is turned on, it will always get information
you can find  maya help
# Suppress all warning and info messages
cmds.scriptEditorInfo(suppressWarnings=True)
cmds.scriptEditorInfo(suppressInfo=True)
maybe can help you~~
