can't install python module with c bindings for maya 2018
hi there,
Using maya 2018 for windows and MS Visual studio 2015.
I'm trying to build/install a python module with c bindings (https://github.com/caseman/noise)
cmd:-
mayapy.exe /path/to/noise/setup.py build
(with following vcvarsall.bat error)
running build
running build_py
running build_ext
building 'noise._simplex' extension
error: Unable to find vcvarsall.bat
I've set env variable %VS140COMNTOOLS% to /program files/VS14/common7/tools, and set it
SET VS90COMNTOOLS=%VS140COMNTOOLS%
if anyone has a work around or better way of doing it - would be highly appreciated.
thanks,
D
ACOLTEL
hello,
I never had this issue before so considere it more as a blind guess than a solution.
May be your computer is missing a dependancy to perform the Build.
You should try to install the compiler package for Python on your computer.
Microsoft Visual C++ Compiler for Python 2.7 :
https://www.microsoft.com/en-us/download/details.aspx?id=44266
Don't know if it will solve your problem but it doesn't harm to try 🙂
Good luck,
Anthony
cheng_xi_li
Autodesk Support
Autodesk Support
I tried to build it and don't have any problems. Here are mysteps:
1. Run vs2015 environment as Administrator(My maya installation is in Program Files which needs Administrator access)
2. Add maya/bin path to path
3. Python setup.py install(I have copied mayapy to python, should be fine directly with mayapy)
Hope it helps.
Yours,
Li
