Best way to delete node specific callbacks
morinnicolas8944
morinnicolas8944
I have a node that uses MNodeMessage::addAttributeChangedCallback in postConstructor to recompute some internal values when its attributes change.
Since there is a separate callback registered for each instance of the node, I want to remove it when the node is deleted.
To do so, I also added a callback with MNodeMessage::addNodePreRemovalCallback which deletes all the callbacks registered for this instance of the node.
This works well when the node is deleted manually, but I noticed that the pre-removal callback is not called when I open a new scene so the callback stays around and is causing problems.
What would be the proper place to remove the callback?
I found this unanswered post which might be related.
https://forums.autodesk.com/t5/maya-programming/callbacks-for-node-removal-no-longer-triggered-when-...
cheng_xi_li
Autodesk Support
Autodesk Support
Maybe MSceneMessage is better, it has scene callbacks for new/open/saving etc...
Yours,
Li
morinnicolas8944
Thanks. I was hoping for something more general, but I guess there is no easy way to handle this.
In the end, I used callbacks for MSceneMessage::kBeforeNew and MSceneMessage::kBeforeOpen to detect when the current file is being closed and its nodes are being deleted. And I used MNodeMessage::addNodePreRemovalCallback to detect when a node is being deleted explicitly. Whenever one of those callbacks gets called, I delete all the callbacks for the current node.
I just hope this is covering all the possible scenarios where a node is removed from the active scene. It would have been nice if all cases had been covered by MNodeMessage::addNodePreRemovalCallback or some other general-purpose deletion callback.
