array compound attribute calling compute() on change
muir.j
muir.j
I'm writing a MPxParticleAttributeMapperNode to color particles arbitrarily and have an array compound attribute that controls the coloring parameters.
However, I can't seem to get the compute() method executing when I make a change to a child attribute with attributeAffects(). How can I ensure this executes each time a child in the array is changed?
e.g. the user changes colorMod[2].color (its an array compound attribute) and hence I would like compute() to be called.
MFnCompoundAttribute cmpAttr;
colorMod = cmpAttr.create("colorMod", "cm", &status);
cmpAttr.setArray(true);
cmpAttr.addChild(startParticle);
cmpAttr.addChild(endParticle);
cmpAttr.addChild(color);
cmpAttr.setReadable(true);
cmpAttr.setUsesArrayDataBuilder(true);
addAttribute(colorMod);
attributeAffects(startParticle, colorMod);
attributeAffects(endParticle, colorMod);
attributeAffects(color, colorMod);
attributeAffects( colorMod, outColorPP);
stuzzz
your need to use MPxNode::setDependentsDirty()
MStatus ziPatchNode::setDependentsDirty(const MPlug &dirtyPlug, MPlugArray &affectedPlugs) {
	MStatus stat;
	MObject thisNode = thisMObject();
	MFnDependencyNode fnThisNode(thisNode);
	if (dirtyPlug== MYATTR ) {
		MPlug toupdate = fnThisNode.findPlug(ATTRTOUPDATE, &stat);
		if (stat) { affectedPlugs.append(toupdate); }
	return stat;
muir.j
I tried setDependantsDirty but it didn't seem to make a difference.
Possibly I am stating the problem wrong?
If I change my color Attribute in the attribute editor or via python, the compute method is not called, but is if I change the animation frame it does evaluate. Possibly missing a callback?
I was hoping just
would do everything.
