animating over time into a python script
corvidstudios
corvidstudios
Hi there, so here's a script adding noise to a 3d object,
and I'm curious to know if its possible to have the noise animated over time?
(I was thinking of multiplying a sin function by time however cannot figure out the way to do it in python)
#add noise to a mesh
import maya.cmds as mc
import random
def addNoise(amt):
    selectedObjs = mc.ls(selection=True)
    obj = selectedObjs[-1]
    numVerts = mc.polyEvaluate(obj, vertex=True)
    randAmt = [0, 0, 0]
    for i in range(0, numVerts):
        for j in range(0, 3):
            randAmt[j] = random.random() * (amt*2) - amt
        vertexStr = "{0}.vtx[{1}]".format(obj, i)
        mc.select(vertexStr, replace=True)
        mc.move(randAmt[0], randAmt[1], randAmt[2], relative=True)
        mc.select(obj, replace=True)
addNoise (0.05)
haggi_master
You could use a randomseed(frame) every time before you call the addNoise().
But the problem is that you use a random function, not a noise function. A random function changes very much (randomly) between every call. A 4D noise function will give you a smooth change over time. Unfortunately there is no built-in noise in Maya as much as I know.
