Announcements
After stroke cmd issue on Sculpt Geometry Tool brushes?
I'm trying to add an after stroke command to the Sculpt Geometry Tool brushes but it seem that the command doesn't get executed (before stroke cmd works fine). I tested different commands but they all seem to get ignored.
Anybody experienced the same problem? Any idea on how to fix this issue?
~B
I am having the same problem. I have submitted it as a bug. I'll let you know if anything comes of it.
In the mean time you may be able to use the duringStrokeCmd(dsk)
WARNING!! this will run many time for each stroke.
artPuttyCtx -e -dsk "" `currentCtx`;
Just run this line of script. Put the cmd you want between the "" and it will apply to the sculpt tools.
Remember to delete it when you're done. Just run the same line above with the "" as is.
Thank you, Scott! I'll give it a try!
Bernardo
Confirmed bug
"afterStrokeCmd was implemented in base artisan but only seems to be called by a few tools"
