AEfileTemplate.mel
AEfileTemplate.mel
AEfileTemplate.mel
Can anyone give me an unchanged AEfileTemplate.mel for Maya 2017 update 3, Windows 64bit? I messed around with it because a lambert I applied was not rendering on an object and I was given a solution....only now I continuously get syntax errors. I don't know that much python but I tried everything I knew to fix it myself. I just need a new, vanilla copy or for someone to correct these lines:
    string $currFile = `getAttr $ftn`;
	if ($currFile != "") {
		int $i;
		string $allTextures[] = `ls -typ file`;
		mentalrayTexture`;
		// this loop is needed to guarantee all texture nodes 		who
		// reference this file gets updated.
		for ($i = 0; $i < size($allTextures); $i++) {
			string $ithFile = `getAttr ($allTextures[$i] + ".ftn")`;
Thanks.
Hi nicnobile
It looks like you have just got a mistake on one of the lines. Try replacing that function with this:
global proc AEfileTextureReloadCmd (string $ftn)
		int $i;
		string $allTextures[] = `ls -typ file -type mentalrayTexture`;
			if ($ithFile == $currFile)
				setAttr ($allTextures[$i] + ".ftn") -type "string" $currFile;
Cheers
Mike
