addCheckReferenceCallback wont take a function as a parameter
I'm currently experimenting with the maya.api.OpenMaya.MSceneMessage to get a feel for in what ways this is useable in a larger setup like my current one
addCallback and addCheckCallback both eork ass expected with an integer and function as arguments
addCheckReferenceCallback, however, continiously gives me:  RuntimeError: (kInvalidParameter): Invalid parameter
That error on it's own doesn't tell me much so instead I tried to inspect the method which just tells me it's not a python method (because of course =(  It can't be that easy!)
This is my test code with which I was trying to feel my way through the MSceneMessage class. How on earth is this method wired or is it just impossible to make this work?
import maya.api.OpenMaya as om
class CallbackMsgHandler(object):
    def __init__(self):
        self.bOpenCall = None
        self.bOpenCheckCall = None
        self.bRefCheckCall = None
    def createSceneCallbacks(self):
        self.bOpenCall = om.MSceneMessage.addCallback(om.MSceneMessage.kBeforeOpen, self.bOpenCallback)
        self.bOpenCheckCall = om.MSceneMessage.addCheckCallback(om.MSceneMessage.kBeforeOpenCheck, self.bOpenCheckCallback)
        self.bRefCheckCall = om.MSceneMessage.addCheckReferenceCallback(om.MSceneMessage.kBeforeLoadReference, self.bLoadRefCallback)#om.MSceneMessage.kBeforeLoadReference, self.bLoadRefCallback)
    def bOpenCallback(self, retCode):
        print "Open Callback"
        print self
        print retCode
        return True
    def bOpenCheckCallback(self, retCode):
        print "Open Check Callback"
        print self
        print retCode
        return True
    def bLoadRefCallback(self, retCode, referenceNode, FileObject):
        print "Open Ref Check Callback"
        print retCode
        print referenceNode
        print FileObject
        return True
handler = CallbackMsgHandler()
handler.createSceneCallbacks()
Nevermind it's me.. I'm an idiot I missed the correct scene message by a word
it's kBeforeLoardReferenceCheck and not kBeforeLoadReference....
Don't code when tired you do really dumb things ^^;
