Add attribute to Alembic ( Long name contains invalid characters )
I need to move my geometry to Katana and to work with instances there I need to add an attribute to the alembic file called 'instance.ID', I already to that with a few other attributes without a problem but Katana needs that dot in this one, specifically.
The dot basically means hierarchy, so ID (a string) would be inside the instance attribute.
Any way I can either write this attribute with the dot or nest ID inside instance? (I'm not sure the second works but I can give it a try.
Here's the line on my code that errors:
intanceID = "instance.ID"
shapeName = "The shape name"
mc.setAttr(i+"."+intanceID, shapeName, type="string",e=True, keyable=False, lock=True)
Thank you
Abel
