AbcExport: How to export the bbox of hierarchical xform nodes?
Message 1 of 1
Hi all,
I'm going to extend Maya2014 AbcExport plugin to export the bbox of hierarchical xform nodes. But I encountered some problems.
For example, here are the hierarchical xform nodes in maya:
group3                              (xform)
   |___group1                       (xform)
   |      |___pCube1                (xform)
   |      |      |____pCubeShape1   (polygon)
   |      |___pCube2                (xform)
   |             |____pCubeShape2   (polygon)
   |___group2                       (xform)
   |      |___pCube3                (xform)
   |      |      |____pCubeShape3   (polygon)
   |      |___pCube4                (xform)
   |             |____pCubeShape4   (polygon)
I'm going to export the bbox of every xform node, e.g. group1, group2, group3, pCube1, pCube2, pCube3, pCube4.
I modified MayaTransformWrite.cpp like this:
class MayaTransformWriter
    Alembic::Abc::OBox3dProperty myTransBoxProp;
    MDagPath myTransDag;
MayaTransformWriter::MayaTransformWriter(Alembic::AbcGeom::OObject & iParent, ...)
    if (iDag.hasFn(MFn::kJoint))
    }else{
            mAttrs = AttributesWriterPtr(new AttributesWriter(cp, up, obj, trans, iTimeIndex, iArgs));
            myTransDag = iDag;// save current dag to myTransDag
            MyTest(myTransDag);
MayaTransformWriter::MayaTransformWriter(MayaTransformWriter & iParent, ...)
    }else{
            MyTest(myTransDag);
void MayaTransformWriter::write()
    size_t numSamples = mAnimChanList.size();
    if (numSamples > 0)
        mSchema.set(mSample);
        MyTest(myTransDag);// use myTransDag
void MayaTransformWriter::MyTest(MDagPath iDag)
    MStatus status;
    unsigned int childCount = iDag.childCount(&status);
    CHECK_MSTATUS(status);
    if(childCount > 0)
        MObject child(iDag.child(0, &status));     CHECK_MSTATUS(status);
        MFnDagNode fnChildDagNode(child, &status);     CHECK_MSTATUS(status);
        MDagPath childDagPath; status = fnChildDagNode.getPath(childDagPath);  CHECK_MSTATUS(status);//
        printf("fnDagNode.getPath(&): %s\n", childDagPath.fullPathName().asChar());
        if(!childDagPath.isValid(&status))
            childDagPath = fnChildDagNode.dagPath(&status);     CHECK_MSTATUS(status);//
            printf("fnDagNode.dagPath()=%s\n", childDagPath.fullPathName().asChar());
        assert(!childDagPath.isNull() && "childDagPath is null");
        if(childDagPath.apiType() == MFn::kMesh) // child node is a mesh shape node
            setAbcBBoxFromNode(fnChildDagNode);
        }else{
            if(isAnimated())
                setAbcBBoxFromNode_animation(iDag); // <---- export the bbox for animation xform node
                //setAbcBBoxFromNode(iDag);
            }else{
    }else{
        printf("it has no child\n");
void MayaTransformWriter::setAbcBBoxFromNode(const MFnDagNode &fnDag)
    transBoxProp = mSchema.getChildBoundsProperty();
    MBoundingBox bbox;
    bbox = fnDag.boundingBox();
    Alembic::Abc::V3d min(bbox.min().x, bbox.min().y, bbox.min().z);
    Alembic::Abc::V3d max(bbox.max().x, bbox.max().y, bbox.max().z);
    Alembic::Abc::Box3d b(min, max);
    transBoxProp.set(b);
void MayaTransformWriter::setAbcBBoxFromNode_animation(const MDagPath &inDagPath)
   //  how to export the bbox for animation xform node?
setAbcBBoxFromNode() can't handle the animation xform correctly, so I have to implement another setAbcBBoxFromNode_animation() for the animation xform node. I tried several ways but failed.
So my questions are:
- I don't know how to implement function setAbcBBoxFromNode_animation(). Could you give me any clue or any suggestion?
- Is there any simpler method to export the bbox of the hierarchical xform node?
Cheers
yao
Replies (0)
