Announcements
3DS Import plugin not loading
Getting the following error when trying to load the 3dsImport plugin, anyone seen this before or know how to fix it?
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/others/pluginWin.mel line 767: Plug-in, "3dsImport" was compiled against too old a version of the Maya API and is thus incompatible with the current Maya version. (3dsImport) //
That means that the plugin you are using -- has not been compiled against the newer Maya.
It is one of the silliest things of Maya -- Everytime a new SDK comes out -- you need to rebuild old plugins with the new SDK. -- Something that is completely broken of Maya.
Only way I can see to fix it -- is well -- to either roll back to an earlier version of Maya -- Or -- find a newer release of that plugin
