2018.5 'str' object is not callable in MASH_QLineEditExtend (repro case)
Narann
Message 1 of 1
Narann
Open Maya:
from Qt.QtWidgets import QApplication
for m in QApplication.instance().allWidgets():
    print m.objectName()
This code is legit as QObject.objectName()  is the property to get the object name: https://doc.qt.io/archives/qt-4.8/qobject.html#objectName-prop
But if the MASH_Distribute tab is open in the Attribute editor, it raise an exception:
# Error: 'str' object is not callable
# Traceback (most recent call last):
#   File "<maya console>", line 11, in <module>
# TypeError: 'str' object is not callable #
plug-ins/MASH/scripts/MASHsingleOutputQtWidget.py
In the class MASH_QLineEditExtend:
self.objectName = "MASH_DropZone"
You should fix this:
self._objectName = "MASH_DropZone"
Please prefix your internal members with undescore to avoid clash in Python. Only exposed member shouldn't have underscore.
Thanks in advance.
Our ugly workaround:
# MASH Distribute attribute editor has some widgets which
# redefine objectName to be a str instead of method
if not callable(m.objectName):
    continue
Replies (0)
