Weird problem with mash in Maya
Hello, the problem is that the clean up in maya swears at some of the geometry, but it's not clear why. It just selects part of the geometry and that's it, even after I select "Cleanup matching polygons" in the clean up settings. There are no n-gons, no non-manifold geometry, no holes in geometry. I will attach a video with the manifestation of the problem and the model itself
mihirsbcc
When I run cleanup  settingremove section I selected Faces with zero geometry area did remove some small faces  now got removed but left holes. Check the image. You probably merge some unnecessary edge-loops. zeroGeometry.JPG
