Vertex Face Effect
Vertex Face Effect
Vertex Face Effect
Hello. Is there a quick way of getting the Vertex Face Effect (Select > Convert Selection > To Vertex Faces) to stay permament (not just for selection) and save into the model file?
The image attached below is the effect needed.
Thanks!
saihtam
1. Select all edges of the object
2. Edit Mesh->Detach
3. Mesh->Separate
4. Select all geo
5. Modify->Center pivot
6. Scale to the disired scale with the scale tool.
Then you can combine it and delete history to get it as one object again.
Let us know if there is anything that's not clear.
- Mathias
Perfect! Thank you!
