UV set copy and delete
I found this script:
string $selectedObjects[] = `ls -sl`;
int $selectionSize = `size($selectedObjects)`;
for ($i = $selectionSize; $i > 0; $i--){
    polyUVSet -currentUVSet -uvSet "uvSet" $selectedObjects;
    polyCopyUV -uvSetNameInput "" -uvSetName "map1"  -ch 1 $selectedObjects;
    polyUVSet -delete $selectedObjects;
//  DeleteHistory $selectedObjects;
however maya gives an error: doesn't work on multiple objects selected. What am I doing wrong to run this script while multiple objects are selected?
mspeer
Hi!
There are many errors in this script. I recommend to use UV Editor and UV Set Editor for these type of operations, but anyway here is a corrected and cut-down version of the script:
int $i;
for ($i = $selectionSize-1; $i >= 0; $i--){
    polyCopyUV -uvSetNameInput "uvSet" -uvSetName "map1"  -ch 1 $selectedObjects[$i];
    polyUVSet -delete -uvSet "uvSet" $selectedObjects[$i];
//  DeleteHistory $selectedObjects[$i];
and a "better" version:
string $sObject;
for ($sObject in $selectedObjects){
    polyCopyUV -uvSetNameInput "uvSet" -uvSetName "map1" $sObject;
    polyUVSet -delete -uvSet "uvSet" $sObject;
//  DeleteHistory $sObject;
Keep in mind that this works only with objects containing at least 2 UV Sets named "uvSet" and "map1".
>>"and a "better" version:"<<
Thanks so much for this, very helpful with 100's of imported objects. 🙂
do you have a version based on the uvset index? i need to delete all uvsets that are not the default one, while the namings are unknown
mspeer
Hi!
// delete all UV Sets except default uv set for all selected objects
string $sObject;
        int $uv_id[] = `polyUVSet -q -allUVSetsIndices $sObject`;
        for ($i in $uv_id) {
            if($i != 0) {
                string $cuvname = `getAttr ($sObject+".uvSet["+$i+"].uvSetName")`;
                polyUVSet -delete -uvSet $cuvname $sObject;
awsome...this comes in handy
