Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
UV connection
3 REPLIES 3
524 Views, 3 Replies
UV connection
Hello! So I've created UVs inside Houdini for this model, and seems like my vertices share connection between different islands.
This causes problem, when I'm importing this mesh to zbrush and doing Subdivs, it stretches (or builds bridges between these same vertices on different islands)
How can I fix that inside Maya? Please help!)
3 REPLIES 3
mspeer
Hi!
I can't see any connections.
In Maya make sure to select only UVs and NOT vertices if you want to move them.
Also check for multiple UV Sets.
in reply to: mspeer
Thank you for answering!
What I mean is that in Zbrush, when I add subdivisions to mesh, it automatically creates bridges between vertices, that share multiple islands. Is that a zbrush problem or Maya?
in reply to: mspeer
Aight, so it was zbrush problem, something hardcoded in document, new doc didn't produce such problems.
