UV Arrange and Layout
Hi there.
Is there a possible way to keep the scale of a UV island when you apply the automatic Layout from the UV editor on your mesh?
I am scaling down some UV islands that are not important but when I apply the UV layout option they go back to their original size. Please check the video.
Alvaro
mspeer
Hi!
Layout is based on selection.
It's not clearly to see in your video, but simply select only the UV shells that you want to use with Layout.
vladislav.terebov
Hi. You can hold Shift button and then click on Layout button to see option window. Under section Shell Pre-Transform Settings turn off Shell Pre-scaling.
Hope this helps.
