Using physics in modelling
Message 1 of 8
Hey guys :D, I'm chasing a method that would save me a ton of time.
How would I "drop" these key models (they are all separate meshes) onto a flat surface using gravity physics, so they can then be exported in a realistic position? instead of placing them tediously onto a flat surface manually.
And obviously id want no clipping to happen, so they just collide and sit on each other realistically too
thnx! 🙂
Replies (7)
Message 2 of 8
mspeer
Hi!
Sorry, but if you want to save "a ton of time", don't use a simulation instead do it manually (looks like a matter of seconds).
The other way would be to use Dynamics like nCloth, Bullet or Legacy Rigid Bodies.
Message 3 of 8
Well i dont know that if I dont know how long it takes to use the other method. And I intend to add a lot more keys, that is a LOT of work to arrange them just right and avoid any clipping on that many items, so I still think it would save me a ton of time to just "drop" the keys into place, done.
Message 4 of 8
mspeer
Hi!
If you are not familiar with the dynamics in Maya i would say you need some hours until you are satisfied with the result.
Message 5 of 8
mspeer
Hi!
Well, i don't know how many keys you want to add, you can try Maya Dynamics for sure, but it's never "just "drop" the keys into place, done".
Message 6 of 8
No im not familiar, hence why im here asking for help..
Message 7 of 8
Bump
Anyone know how to add physics to these keys so I can then export its final position after being dropped? thnx
Message 8 of 8
damaggio
Hi Jacob , as well
suggested by mspeer , you could try using Maya's dynamics and ncloth , there are many tutorials on you tube that you can find as well google, Lynda .com and pluralsight.
It's a somewhat complex process to quickly cover in the forum.
you can come back if you are stuck in a specific step.
best of luck.
