Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Using multi cut tool while mouse is set to single button setting
1 REPLY 1
314 Views, 1 Reply
Hi.
I'm new to Maya (2022) and I am using an iMac. My mouse is the standard magic mouse that came with the mac and as such only has one button. As a result, I set my mouse settings to single-button mouse and it works well for other things like the marking menu etc. However, when it comes time to use the multi cut tool, I have to switch to the two-button mouse setting, because the single-button mouse setting confuses the "ctrl key + left button click" combination as a "right click" which then brings up the marking menu. And when I let the "ctrl" key go, the edge loop remains, but I can't lock it in using a mouse click or keys like "enter".
While, I can create the edge loop using the two-button mouse setting, I feel that this is inefficient and time consuming. Can anyone tell me if there is a way to use the multi cut tool with the single-button mouse setting?
Labels (1)
1 REPLY 1
zewt
I know it's not the answer you're looking for, but you'll have a much better time with Maya (and probably lots of other tools) if you get a standard three-button mouse...
