User Defined Properties in Maya
slava.lobanov.1990
slava.lobanov.1990
Hi. In 3ds Max there is an option for setting custom properties. How to do this in Maya? In 3ds max, I can write any belief there and export it to fbx.
hamsterHamster
Sorry, your question is unclear - what properties you want to change?
If the thing is supported by FBX format, and you can find it in the File>ExportSelection.. file browser dialog..
.. then it can be done here too. And, I beleive, it is true even more so from Maya than Max, as historically Alias appropriated FBX from Kaydara, which happened long before Autodesk bought Maya.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
slava.lobanov.1990
Model: 2903037336768, "Model::Box001", "Mesh" {
Version: 232
Properties70: {
P: "PreRotation", "Vector3D", "Vector", "",-90,-0,0
P: "RotationActive", "bool", "", "",1
P: "InheritType", "enum", "", "",1
P: "ScalingMax", "Vector3D", "Vector", "",0,0,0
P: "DefaultAttributeIndex", "int", "Integer", "",0
P: "Lcl Translation", "Lcl Translation", "", "A",5.7298755645752,0,-4.63847160339355
P: "UDP3DSMAX", "KString", "", "U", "surface=1&cr;&lf;"
P: "MaxHandle", "int", "Integer", "UH",2
Shading: T
Culling: "CullingOff"
P: "UDP3DSMAX", "KString", "", "U", "surface=1&cr;&lf;" This parametr in fbx file.
slava.lobanov.1990
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMa...
User-defined Properties
The FBX file format supports 3ds Max user-defined properties. They are stored in the FBX file as custom properties and labeled as UDP3DSMAX.
hamsterHamster
You can add your own custom attributes to supported nodes, like poygons and joints, and those will be exported to FBX.
Here is identical page from Maya Help https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-0ACDAC13-D16E-424B-829F-25E1E255A8DF, see CustomProperties section. The only cosmetic difference is that the Max version speaks about UI gizmos to represent various data, while in Maya it is described from a data-type standpoint, which is identical to how data is kept within FBX files. Like, Max-wise, FBX supports BooleanCheckbox and BooleanButton, while in Maya they mention general Boolean data type, which can be represented either as data field with [on/off] states (e.g. in ChannelEditor) or a "boolean" checkbox (in AttributeEditor) - under the hood the data is still BOOL type in both Max and Maya.
,,,_°(O__O)°_,,,
