Unfold Uv keeps causing maya crash (Maya 2023 ver)
3169813
3169813
I try to Uv unfold my model in Maya and the program keeps on crashing. I tried resetting the preferences (display, viewport 2.0 from Open Gl to Direct X), Reset Maya preferences (I followed this https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May... Restarting maya etc.
I tried Most of the soluutions that I can find via autodesk and google, but nothing works 😕
Here is a screenshot of what is shown after it crashes. (Image attached below1234.PNG)
This is what is shown in the crash log:
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0xA8A9A000
Fault address: 18E79EFC in C:\Program Files\Autodesk\Maya2023\bin\unfold3dlib.dll
0001:00138EFC Logical offset (see .map file for location)
Call stack:
Module: C:\Program Files\Autodesk\Maya2023\bin\unfold3dlib.dll (-exported-)
Decl: ??
Decl: ??
Decl: ??
Location: unfold3dlib.dllNU3D::CVector3::GetRaw + 13D7 bytes
Decl: public: double const * __ptr64 __cdecl NU3D::CVector3::GetRaw(void)const __ptr64
Location: unfold3dlib.dllNU3D::CVector3::GetRaw + D59 bytes
Location: unfold3dlib.dllNU3D::CTaskSetLibParams::Definition + 13729 bytes
Decl: public: static class NU3D::CRef __cdecl NU3D::CTaskSetLibParams::Definition(void)
Location: unfold3dlib.dllNU3D::CTaskSetLibParams::Definition + 12944 bytes
Location: unfold3dlib.dllNU3D::CTaskWeldParams::~CTaskWeldParams + 19C97 bytes
Decl: public: virtual __cdecl NU3D::CTaskWeldParams::~CTaskWeldParams(void) __ptr64
Location: unfold3dlib.dllNU3D::CTaskWeldParams::~CTaskWeldParams + 18E46 bytes
Location: unfold3dlib.dllNU3D::CTaskWeldParams::~CTaskWeldParams + 17D54 bytes
Location: unfold3dlib.dllNU3D::CTaskWeldParams::~CTaskWeldParams + 1C31F bytes
Location: unfold3dlib.dllNU3D::CUnfold3DAPI::Do + 119 bytes
Decl: public: class NU3D::CRef __cdecl NU3D::CUnfold3DAPI::Do(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const & __ptr64,class NU3D::CRef) __ptr64
Module: C:\Program Files\Autodesk\Maya2023\bin\plug-ins\Unfold3D.mll (-exported-)
Decl: class Autodesk::Maya::OpenMaya20230000::MStatus __cdecl uninitializePlugin(class Autodesk::Maya::OpenMaya20230000::MObject)
Decl: ??
Module: C:\Program Files\Autodesk\Maya2023\bin\OpenMaya.dll (-exported-)
Location: OpenMaya.dllAutodesk::Maya::OpenMaya20230000::MPxMultiPolyTweakUVCommand::doIt + 5C0 bytes
Decl: private: virtual class Autodesk::Maya::OpenMaya20230000::MStatus __cdecl Autodesk::Maya::OpenMaya20230000::MPxMultiPolyTweakUVCommand::doIt(class Autodesk::Maya::OpenMaya20230000::MArgList const & __ptr64) __ptr64
Decl: public: virtual int __cdecl THcommandObject::doIt(class TargList & __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2023\bin\CommandEngine.dll (-exported-)
Location: CommandEngine.dllTmetaCommand::doCommand + 5D bytes
Decl: public: virtual bool __cdecl TmetaCommand::doCommand(class TargList & __ptr64) __ptr64
Location: CommandEngine.dllTjournal::operator= + 4F6 bytes
Decl: public: class Tjournal & __ptr64 __cdecl Tjournal::operator=(class Tjournal const & __ptr64) __ptr64
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 21C bytes
Decl: void __cdecl setMelGlobalStackLevelPtr(unsigned int (__cdecl*)(void))
Location: CommandEngine.dllSophiaExecutable::evaluate + 47 bytes
Decl: public: union Value * __ptr64 __cdecl SophiaExecutable::evaluate(void * __ptr64) __ptr64
Location: CommandEngine.dllTcommandEngine::executeCommand + A6 bytes
Decl: public: int __cdecl TcommandEngine::executeCommand(class SophiaExecutable * __ptr64) __ptr64
Module: C:\Program Files\Autodesk\Maya2023\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTrepeatCommandManager::getCommandString + D01 bytes
Decl: public: void __cdecl TrepeatCommandManager::getCommandString(class std::_List_const_iterator<class std::_List_val<struct std::_List_simple_types<class TnameCommandObject * __ptr64> > >,class Tstring & __ptr64) __ptr64
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + C63 bytes
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + D38 bytes
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 728 bytes
Location: CommandEngine.dllTcommandEngine::executeCommand + 3FC bytes
Decl: public: int __cdecl TcommandEngine::executeCommand(class Tstring const & __ptr64,bool,bool,class TmelCmdResult * __ptr64,unsigned int) __ptr64
Location: ExtensionLayer.dllTscriptActionMixin::execute + 1F7 bytes
Decl: protected: bool __cdecl TscriptActionMixin::execute(class Tevent const & __ptr64,class std::unique_ptr<class TinterpreterResult,struct std::default_delete<class TinterpreterResult> > * __ptr64) __ptr64
Location: ExtensionLayer.dllTrunTimeCommand::doCommand + CC bytes
Decl: public: virtual bool __cdecl TrunTimeCommand::doCommand(class TargList & __ptr64) __ptr64
Location: ExtensionLayer.dllTaction::performAction + C8 bytes
Decl: private: void __cdecl Taction::performAction(class Tevent const & __ptr64,char const * __ptr64) __ptr64
Decl: public: void __cdecl Taction::doIt(void) __ptr64
Module: C:\Program Files\Autodesk\Maya2023\bin\Qt5Core.dll (-exported-)
Location: Qt5Core.dllQObject::qt_static_metacall + 1467 bytes
Decl: private: static void __cdecl QObject::qt_static_metacall(class QObject * __ptr64,enum QMetaObject::Call,int,void * __ptr64 * __ptr64)
Module: C:\Program Files\Autodesk\Maya2023\bin\Qt5Widgets.dll (-exported-)
Decl: public: void __cdecl QAction::activate(enum QAction::ActionEvent) __ptr64
Location: ExtensionLayer.dllQmayaMarkMenuController::execMarkingMenu + 41E bytes
Decl: public: static void __cdecl QmayaMarkMenuController::execMarkingMenu(class QMenu * __ptr64,class QMouseEvent * __ptr64)
Location: ExtensionLayer.dllQmayaQtHelper::execMenu + 8B bytes
Decl: public: static void __cdecl QmayaQtHelper::execMenu(class QWidget * __ptr64,class QMenu * __ptr64,class QMouseEvent * __ptr64,bool)
Location: ExtensionLayer.dllQmayaQtHelper::handlePopupMenu + 278 bytes
Decl: public: static bool __cdecl QmayaQtHelper::handlePopupMenu(class QObject * __ptr64,class QEvent * __ptr64)
Location: ExtensionLayer.dllQmayaQtHelper::handlePopupMenu + 3C5 bytes
Location: Qt5Core.dllQCoreApplicationPrivate::sendThroughObjectEventFilters + DA bytes
Decl: public: static bool __cdecl QCoreApplicationPrivate::sendThroughObjectEventFilters(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + FC bytes
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplication::notify + 750 bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: ExtensionLayer.dllQmayaApplication::currentSystemMouseButtons + 671 bytes
Decl: public: static class QFlags<enum Qt::MouseButton> __cdecl QmayaApplication::currentSystemMouseButtons(void)
Location: Qt5Core.dllQCoreApplication::notifyInternal2 + BA bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Widgets.dllQApplicationPrivate::sendMouseEvent + 3C5 bytes
Decl: public: static bool __cdecl QApplicationPrivate::sendMouseEvent(class QWidget * __ptr64,class QMouseEvent * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64 * __ptr64,class QPointer<class QWidget> & __ptr64,bool,bool)
Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + 2D3A bytes
Decl: public: __cdecl QSizePolicy::QSizePolicy(void) __ptr64
Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + CBE bytes
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 110 bytes
Location: Qt5Widgets.dllQApplication::notify + 18B3 bytes
Module: C:\Program Files\Autodesk\Maya2023\bin\Qt5Gui.dll (-exported-)
Location: Qt5Gui.dllQGuiApplicationPrivate::processMouseEvent + 936 bytes
Decl: public: static void __cdecl QGuiApplicationPrivate::processMouseEvent(class QWindowSystemInterfacePrivate::MouseEvent * __ptr64)
Location: Qt5Gui.dllQWindowSystemInterface::sendWindowSystemEvents + 90 bytes
Decl: public: static bool __cdecl QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 6A bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Module: C:\Program Files\Autodesk\Maya2023\plugins\platforms\qwindows.dll (-exported-)
Location: qwindows.dllqt_plugin_query_metadata + 1F99 bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: Qt5Core.dllQCoreApplication::exec + 154 bytes
Decl: public: static int __cdecl QCoreApplication::exec(void)
Location: ExtensionLayer.dllTapplication::start + E5 bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module: C:\Program Files\Autodesk\Maya2023\bin\maya.exe (-exported-)
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 1490 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 17E77 bytes
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 16FAA bytes
Module: C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
Module: C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
End of stack
Christoph_Schaedl
Could you post the scene here?
https://linktr.ee/cg_oglu
3169813
Hi, thanks for the response. I don't really know what I did, but somehow it resolve by itself after numerous crashes and attempt of resetting preferences.
erinelizabet
Community Visitor
Community Visitor
I am having the same issue actually! I hope that my issue will resolve like yours did after multiple crashes. I've had to re-install the program and it's still doing it.
Christoph_Schaedl
Could you post the crashing mesh?
