Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
twistet
8 REPLIES 8
Message 1 of 9
stefan.klingenberger
566 Views, 8 Replies
twistet
hello,
i extrude a circle along curve (the curve is closed). unfortunately  is the start/ end of the extruded object twistet.
how can i rotate or untwistet it, so i looks like closed.
or is it possible to close the extruded object?
8 REPLIES 8
Message 2 of 9
Hi!
Too much information missing, please upload a scene-file.
Message 3 of 9
I'd recommend extruding along an open curve, with the start object at one end of the curve (also make sure the Taper and Twist settings are both 0).  This will produce a much more predictable result.  Once it's extruded, you can delete the faces on each end and then weld the start and end vertices together.
Matt C
Senior Content Experience Designer
Maya Documentation | Maya Learning Channel |
Message 4 of 9
hey,
thanks for your tipps and sorry that i answer so late. i did a lot of test but found no solution.
i modelled a Möbius Strip with a cube, selected one of the outline Edge (no matter which outline) of the cube and extrude a triangle.
the Problem is the Twist deformer.
after 360° deforming, there is Always a gap.
but you´re Right, it´s possible to weld it but it Looks a Little bit unclean
Message 5 of 9
Hmm, given the selection colors is it right to assume there's two objects in there?
I was able to achieve this using a Twist deformer + a Bend deformer on top of that.  As long as the twist is a multiple of 180, the edges will line up.  If they're not a multiple of 180, then mathematically they shouldn't line up.
Matt C
Message 6 of 9
you are right again. it will perfect work but I used the edges of the white cube because i will animate the möbius strip (rotate the main cube and the extruded objects will follow)
the white one is the (möbius) cube. I create a triangle curve object, selected an edge of the möbius cube and extruded it (the green one). i tried to post the scene but it dosen´t work. maybe it´s not zipped?
Message 7 of 9
Ah I understand now.  Instead of an extruded triangle, I'd suggest you use a cylinder primitive reduced to 3 sides.  The reason you're having a problem is that the extruded geometry gets a little mangled going through a deformer (especially because it has no caps).  Even on a twist alone, you probably noticed the tips of the extruded geometry tilt rather than stay straight.
I've attached your same scene file with the fix included.
Matt C
Message 8 of 9
hey Matt,
you did it!!!!
perfect, this is exactly what i want. thank you very much.
but last question...how did you deform the new triangle mesh on the curve of the big cube???
Message 9 of 9
I just selected them both when creating each deformer.  That way they're both affected.
Matt C
