topology problems
topology problems
topology problems
I cant select some vertices behind the grey polygon when I using quadraw. it seems those vertices are behind the mesh I want to topo. Do anyone know why?
hey, you have not enougth polygon too correct "projection" you can try smooth now with shift and make it soft selected with "b" on, or can try sub div 1 time and smooth quad draw after
