Hi all, I'm seriously stumped by this and don't know what i'm doing wrong. I'm new to maya so hopefully you kind folks can help me out.
So basically, I was following this video tutorial: Maya Tutorial - Create a Tube from a Curve about surface extruding a circle curve along a EP curve to create a tube-like object. The first time I followed this method it worked perfectly. However, a couple days later, i tried it again and it just won't extrude the same way no matter what I try. The image i've attached shows the left one which i did correctly, and the right one which is incorrect. I can see that all the verticies/edges are all skewing in the same direction, which is causing the flattened look, but i can't figure out how to fix it. I used the extact same surface extrude settings that the tutorial video had.
If you kind folks could help me out, that would be greatly appreciated
Are the transforms frozen?
