Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Surface Continuity checking in Maya
5 REPLIES 5
2958 Views, 5 Replies
Hey Guys,
i would like to know if there are any kind of tools/shading options in maya to check the surface continuity of your Nurbs Surfaces.
A example would be the zebra stripes as in Alias or Rhino.
It doesnt have to be zebra stripes since i am sure Maya does not have those. I am fine with any kind of diagnostic shading that checks the continuity of your surfaces.
It would be awesome if someone could tell if such a thing exists!
Cheers!
5 REPLIES 5
pshwayka
Would the checkerboard texture work for you?
_sebastian_f
in reply to: pshwayka
@pshwayka: i don´t think thats what he wants.
@Anonymous
unfortunately maya doesn´t has it by default. but you can create something like a zebra quite easy.
it´s not excactly the same like the alias one but should be enough for a quick check.
wih similar methods you can also create other verions of the diagnostic in alias.
in reply to: _sebastian_f
Hey Guys,
first of all thanks a lot for your suggestions! And a big sorry for not responding sooner - usually i get a e mail if someone replies to my threads in other autodesk forums - i have that option on by default - but it seems that it did not work this time!
Sorry for the huge delay! I thought about this again today an remembered my thread!
Thanks again - i thought about doing it via the texture - the thing i was unsure about was if there is some underlying calculation going on in something like Alias - if that is not the case and its purely an applied texture that has a pattern on it that makes it easy to spot flaws than thats of course perfect to me.
Sorry - i come originally from drawing and sketching cars so the whole 3D thing is pretty new to me!
Is there a lot happening with NURBS still? I mean from a development perspective? Most of the new improvements seem to be centered around the Modeling Toolkit. I like where both methods of modeling are right now - i just hope people dont forget about NURBS modeling - i really like it!
joostkonemann
If you use Arnold you can also use a aiUtility shader set to 'Reflection Lines' color mode. It gives results like the attached image. Though it is not live in the viewport.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
Yes, this comes really long after your post have been made, just for anyone who has googled this recently.
I made a quick tutorial on 3D modeling artifacts and like others who have replied I use a flow check map in the reflection slot to check my surface.
You can download a colorful flow map similar to the zebra map but only looks more cool 🙂 here: https://gum.co/jlvkd
and these are two articles, one on 3D modeling cars in polygons and why you need to test with a flow check map here: www.ebalstudios.com/blog/modeling-cars-polygons
And another on mo 3D modeling artifacts and it goes into the flow check map: www.ebalstudios.com/blog/3d-modeling-artifacts-flow-check-reflection-map
