Selection problem 2017
Message 1 of 10
I just installed Maya 2017 and am working in a scene with multiple object in close proximity. It seems that my cursor now selects objects when it hovers off to the side and not necessarily when it is hovering directly over it. I have attached a picture that shows this strange behavior. It makes it very difficult to model and selects objects in tight spaces so solving this will definitely be a huge help!
Replies (9)
Message 2 of 10
mspeer
Hi!
Please go to Windows -> Settings/Preferences -> Settings -> Selection and try setting values that better fits your needs.
Message 3 of 10
s_poliakov
playing with numbers doesnt help there. Under some persp angles objects and components are randomly unselectable
Message 4 of 10
mspeer
Hi!
Can you please try the following to see if it makes a difference...
1. Try the same with the legacy viewports
2. Select the camera (View -> Select Camera)  and in Camera Attributes set the value for Far Clip Plane to a lower value, try lowering to a value just before your objects disappear.
or even better can you upload a file where this happens?
Message 5 of 10
s_poliakov
https://drive.google.com/open?id=0BzyNE3pq16elMTQ2dWtRdGljcDQ
Uploaded are the scene and a video of my clicking around trying to find the area and angle where selection would work.
Changing viewport to legacy ones presumably helps - though it's not a viable solution.
Changing far clip plane settings doesn't seem to help. I'm using a script that sets some comfortable camera and mesh display values. It has proved to be the happy middle ground for dozens of projects with different model scales. So, in my opinion it's a glitch of viewport 2.0
Message 6 of 10
mspeer
Hi!
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Workaround:
A) Using the 3 key  (smooth mesh preview) on the background model seems to make it easier to select the foreground object.
B) Use Display Layers to make some objects not selectable ( Display Type: Reference)
Message 7 of 10
brentmc
Try changing your Preferences > Display > Rendering Engine  to DirectX 11 and restarting Maya.
Thanks.
Brent
Brent McPherson
Principle Engineer
Message 8 of 10
Changing click box size to 1 in selection preferences has helped, thanks a lot!
Message 9 of 10
Changing viewport 2.0 to Legacy Default  Viewport : that's what worked with me.  Thanx a lot!
Message 10 of 10
in preferences > selection  .  check on  ( camera based selection )
