rotating two seperate objects
selvakvigneshmaya
selvakvigneshmaya
when rotating 2object all small objects move together but when moving first object thats not the same thing happening
i can use combine first then do the separate after rotating but is there any other idea
why is that pivot point not showing in the second object ex 1 (when combined and separated its no more)before rotation (all are sepearate)before rotation (all are sepearate)object 2 after rotationobject 2 after rotationobject 1 after rotation (if combined and seperated rotates fine)object 1 after rotation (if combined and seperated rotates fine)https://drive.google.com/file/d/1b6i0gG_MSdMRfrB5USUockeFD1vBV2w_/view?usp=sharing
Kahylan
Hi!
Hold down E and leftclick into the viewport. In the dropdown Menu that appears check if "Rotate Object Center" is turned on. If it is, turn it off.
I hope this helps!
selvakvigneshmaya
rotate object centre is unchecked.is there any other way
Kahylan
Ok if that is unchecked it is probably your Rotate Center Setting. Go into the Rotate Tool Settings (doubleclick the rotate tool on the left of your screen). next to "Rotate Center" check either "Manip" or "Selection". Manip should set the rotation center to the rotation center of the last selected object, Selection sets the rotation center to the average of the rotation center of all selected objects.
I hope this helps!
selvakvigneshmaya
thank you  gave a clear solution
