Regularize Loop
Regularize Loop
rarencibiaTUJ4U
Regularize Loop
rarencibiaTUJ4U
Hi Guys, I'm moving from max to Maya and I wonder if there is any script to regularize loops or faces like in 3ds max?
Kahylan
Hi!
I'm not familiar with Max so I'm not quite sure what script you were using to regularize loops. But most scripts I found when I googled did the same as mayas circularize tool, which you can find under Edit Mesh -> Circularize (requires maya 2020 or newer).
If this isn't what you are looking for, could you please link me the script you were using in Max so I can be of further help.
I hope it helps!
