Announcements
Question
saidmurodovsaidazim21
Observer
Question
Observer
Observer
Hello everyone, I have shift+left mouse, i.e. extrude is not working, how to fix it
Christoph_Schaedl
What exactly is not working?
And please name the thread next time accordingly to your question.
https://linktr.ee/cg_oglu
arslanbut9090
Community Visitor
Community Visitor
If you're experiencing issues with the shift+left mouse (extrude) function, especially in a software application like a 3D modeling program, here are a few steps you can take to troubleshoot and potentially resolve the problem:
  1. Check Keyboard and Mouse Settings:
    • Ensure that your keyboard and mouse are functioning correctly. Sometimes, hardware issues can cause specific key combinations to not register.
  2. Software-Specific Settings:
    • In the 3D modeling software you're using, check if there are any specific settings related to the extrude function. Look for keybinding configurations or preferences that might affect the behavior of the shift+left mouse action.
  3. Update Software:
    • Ensure that you are using the latest version of the 3D modeling software. Software updates often include bug fixes and improvements that might address issues with certain functions.
  4. Graphics Drivers:
    • Make sure your graphics drivers are up to date. Outdated or incompatible graphics drivers can sometimes cause issues with certain features in 3D modeling applications.
  5. Check for Conflicting Shortcuts:
    • Verify that there are no conflicting keyboard shortcuts that might interfere with the shift+left mouse function. Some software allows users to customize shortcuts, and conflicts could arise.
  6. Reset Preferences:
    • Some 3D modeling software allows you to reset preferences or user settings to default. Check if there's an option to reset preferences and see if it resolves the issue.
  7. Update Mouse Drivers:
    • If you're using a specialized mouse, check if there are any driver updates available. Outdated mouse drivers can sometimes cause unexpected behavior.
  8. Check Documentation or Forums:
    • Refer to the software's official documentation or user forums. Other users might have experienced similar issues, and there could be solutions or workarounds provided by the community.
  9. Contact Support:
    • If the issue persists, consider reaching out to the support channels of the 3D modeling software. They may provide specific guidance based on your software version and system configuration.
  10. Try Another Mouse:
    • If possible, try using another mouse to see if the issue persists. This can help determine if the problem is related to the mouse itself.
Remember to save your work before making significant changes to settings or preferences. If all else fails, contacting the support channels of the specific software you're using would be a good next step.
