Whenever I use the marquee select tool to select a bunch of faces at once, it includes a bunch of faces on the opposite side of my cube. So I now hafta select one face at a time using shift select, which takes a long time.
I made sure symmetry is turned off, but the bug is still happening.
I even deleting the User Prefs file, but the bug is still happening.
Please help me!!!!!!
Solved by mspeer. Go to Solution.
Solved by tony.su. Go to Solution.
check camera-based selection option.
Hi!
You may try Camera-based selection ("enable").
Read more about Select Tool in the Maya Online Help / Documentation
If this does not help, please provide more details and upload a scene-file that shows the problem.
Hi!
Thank you! It worked!
