Problem in UV mapping
Message 1 of 22
Hi!
I need a help. I have problem in UV mapping. In vain I follow the tutorials (material and UV mapping), i don't understand now.
There is video link about problem: https://youtu.be/LEE5Z4SXjuQ
I'm deaf and i'm student in SZE University, Győr Hungary. Beginner programmers learn.
I hope you can help the problem.
Thank you for help. Marcell
Replies (21)
Message 2 of 22
damaggio
Make sure you are not creating more than one uv map, in the uv editor top bar Textures> uv map 1 should be the only one , also make sure in your lambert nothing is connected to transparency and turn file texture filter to off, lets us know if it helped any .
Message 3 of 22
I don't understand. How fix it need UV one map. Alternative solving, or i using other material?
Message 4 of 22
damaggio
I'm driving home give me half hour.
Message 5 of 22
Okay, i waiting. Thank you!
Message 6 of 22
damaggio
Always use a new shader, avoid working with default Lambert 1....See if this helps...
Message 7 of 22
damaggio
Also the display filtering is only for the viewport, not for the final render.
Message 8 of 22
damaggio
Hold on I'm looking at it.
Message 9 of 22
damaggio
You are not deleting history u94, you have to delete history all the time, specially when doing UVs and freeze transformations, there's nothing wrong with the file other than that, the texture I made is tiny too 256.
Message 10 of 22
Edit > Delete by Type > History, yes?
Message 11 of 22
damaggio
Also you can improve the wireframe display in the viewport Viewport 2.0>Anti Aliasing smooth wireframe Multisampling 8
Message 12 of 22
damaggio
And your image is 16 not 256 you must have made a mistake, 16 will never work its smaller than a Maya Icon...its gotta be a mistake.make it 256 in size inphotoshop.
Message 13 of 22
No work, same 😞
Message 14 of 22
damaggio
Yes, unless you have rigged characters or deformers then you have use Delete non deformer History....you don't have anything like that.
Message 15 of 22
damaggio
Redo your texture in photoshop 256X256 and don't make image blurred, make the color lines straight solid colors, no blur on image.
Message 16 of 22
Blurry image in Photoshop (sorry hungarian language). képpont=pixel. Please make it, and send me.
I was zoom 3200%
Message 17 of 22
damaggio
like this ....
Message 18 of 22
damaggio
Message 19 of 22
Unfortunately, Maya crashed in UV mapping. Is Maya 2016 not stable verison.
My system specification:
AMD FX-6300 3.5GHz processor
AMD Radeon R7 260x 2GB video card
8GB RAM
Windows 7 64bit
Message 20 of 22
damaggio
Make sure your AMD card is up to date , 8 gb of ram is kind of low , Maya needs a lot to run properly, just make sure you work in a Maya . ma file and not . mb file and use incremental save just in case.
maya should save a crash file in your Temp folder.
