Problem about pivot when I extrude edge or face!!! T_T
Hello, I seriously need help.. with maya 2016 extension 2.
As you see below, whenever I'm using exturde, the pivot shows in a different type.
How can I change it to usual shape of pivot??
T_T the pivot that shows has only one arrow with square in the middle...
undefined
pshwayka
It's because you have symmetry enabled. I think it's a bug.
Thanks! you're totally right...!!
brentmc
It is not a bug.
If we cannot support an operation symmetrically then it will be blocked because when modeling symmetrically we do not want to allow operations that will break symmetry.
In this case simply disable symmetry or hit W to switch to the move tool to restore full editing functionality.
Brent McPherson
Principle Engineer
pshwayka
Really? Then why does the example below not get "blocked?" It indeed breaks symmetry.
Steps:
  1. Create a standard cube. Enable Object X Symmetry.
  2. Select a top edge of the cube and extrude using the handle.
  3. Hit "G" to extrude again and use the handle. Note that symmetry is now broken.
I've also included a screenshot of the same operation using Modo's Edge Extend tool in symmetry mode. Note that it works as expected...
undefined
undefined
damaggio
Hi Brent, I get the same results and even if the extrude edge is from a valid piece of geometry the manipulator still doesn't show up as it should, thus slowing the modeling process once again instead of speeding it.
Even if a modeler wants to extrude and edge in the wrong fashion, the extrusion symmetry should work and the manipulator should be available, is clearly something to take up with the developing team and finish the tool properly before releasing..
brentmc
Yes, that is a bug. Hitting W and using the move tool gives the correct results.
Thanks.
Brent McPherson
Principle Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
