Can someone help me please, my Pivot scales with camera and i don't want it to do so. the problem is; when i zoom out, the Pivot gets bigger and when i zoom in it gets smaller. How do i disable this setting??
Solved by Liing1. Go to Solution.
Hi @Liing1 welcome to the community!
Can I ask why you want to change this feature? This is how the gizmo is set up by default and I'm not 100% sure if it can be changed. If you could post a screenshot or two showing your issue and explain it a little bit more I'll see if I can help you out.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
