Option missing
Option missing
Option missing
Hello Community.
I have a little problem. Today I open Maya and I want to make an extrude or bevel. But when I do that, I don't have the little window of option. And My channel box is pretty empty.
Sorry for my English.
trevor.adams
Hi @Anonymous,
Which version of Maya are you using?  If you're referring to the In-View Editors for Extrude or Bevel (little window that pops up when you run either of those operations, allowing you to quickly edit associated attributes), if they're not showing up, you can press T on your keyboard.  That will work as long as your extrude or bevel node is active/selected (which is the case after running these operations).  [Pressing T enables "Show Manips" which is what's required to be active in order to see In-View Editors - by default, this is auto-enabled after running an In-View Editor-compatible operation like Extrude or Bevel.]  If you notice the Extrude or Bevel attributes aren't showing up in the Channel Box, make sure the node is selected by reselecting it in the Channel Box (directly under "INPUTS").
Hope that helps!
Trevor Adams
Maya Design Team Manager, Mudbox Designer, Maya Modeling Designer
Twitter | LinkedIn
##- Thanks for your answer. Finally I erase the folder of pref. And all is
reinitialized. -##
